Stainless Steel To Copper Pipe Adapter
Hi: I've got an unusual application (for me, anyway) which requires an adapter to take me from stainless steel pipe (probably sch 10) to type 'L' copper pipe. This would all be 2" and under, and needs to meet ASME pressure piping code standards for oxygen service. I'd rather not get into fabricating these (or having them fabricated), if there's already a component on the market that'll take me where I need to go. The SS end could be socket or butt weld, and the copper end could be either male or female, suitable for silver soldering or brazing.
Thanks.
Thanks.
RE: Stainless Steel To Copper Pipe Adapter
You did not specify conditions( T, P, GOX, LOX),
but two options are 1) flange both pipes and connect them; or 2) Swagelok has some adapter fittings in sizes to 2", mostly to 1"
Thanks for your response.
