Sewage Lagoon Berm Elevation
Starting a project with raising the berm elevation an existing sewage lagoon has been identified as an option. The increase in berm elevation would serve to add protection to the lagoons from a lake that periodically reaches flood elevations.
I am looking for potential issues that might arise with the city sewage system when raising the berm elevation.
RE: Sewage Lagoon Berm Elevation
Increasing the lagoon berm should not cause any problems at the the treatment plant.
However, if you are discharging against a higher elevation (in a flood for example), you will have to have an effluent pump station.
