Breaker status indication
I have to lay control cables from switchgear to PLC control panel for the status of breakers and control switches. does this cable has to be shielded as these are for Digital Input to PLC. and should it be separate from current signal which is analog 4-20mA shielded.
I appreciate your comments
RE: Breaker status indication
If it is broken, fix it. If it isn't broken, I'll soon fix that.
