Launch a .bat file inside a macro
Is it possible with NX5 to launch a dos file .bat inside a macro playback ?
It's very easy with Ideas
Thanks in advance
Didier
Thanks in advance
Didier
RE: Launch a .bat file inside a macro
Doc
http://www.goodrich.com
Macro's however are limited to interacting with NX commands. One suspects that you ought to be able to do it from a journal by including the extra programming directly. If so it may be found by searching the forum as there's a slight chance the question has been asked before. Otherwise like you I'm keen to have some enterprising user post the code.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
find herewith more information about my request:
l need to create a note on drawing with complete path and of the displayed part
l found the following solution
1: execute a macro that create nx log file
2: execute a bat file that modify nxlogfile with only the following line
(string) path="c:\...\partname.prt"
3: execute a macro that import nxlogfile.exp in expressions
so, i have to launch step 2 from step 1, then launch step 3
actually, i have a toolbar with 3 icons
i am not an expert with grip or vb to do this
thanks in advance
didier
This program extracts the complete file specification
path for the current part file and writes this information
into a Part Attribute.
This program must be run while a Part file is Open.
All you need to do now is create your note referencing the value of the Part Attribute.
As before, after downloading, edit the file extension from .zipper to .zip before extracting the content.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Yes it is possible but I'm glad you're offering to program
it for us because it certainly isn't necessarily easy.
You'd need to consider what the attributes you wish to duplicate are or whether you interrogate whatever attributes you can find in each components and simple assign them some sort of duplicate instance in the top assembly. Then you need to know how many components there are and whether you wish to go down one level or into all the sub-assemblies in the tree.
Having considered all those and other aspects of what you require such a program to achieve you then need to address how you're going to use and maintain that data and why other existing tools might do a better job if you adapted them to a similar purpose. Why? Because most of the time what you want to do talks about the same kinds of things that parts lists already do better in most cases.
Some solutions may make limited use of GRIP, others will require anything from macros and journals through to advanced c programming skills. Unfortunately for most of us you have to want a specific customisation pretty badly before you're willing to expend time and resources in the creation of such code.
Notably we have recently posted at length about how to use annotations with relationships to attributes or expressions you'll find several recent posts by searching. They address functionality found under the annotation editor and using tables. When you have read up a bit more and are perhaps willing to discuss your specific requirements we might be able to offer a couple of pointers. I'd urge you then to start your own thread on it in that vein.
Best Regards
Hudson
www.jamb.com.au
This program reads and then creates a report (displayed on the current listing device) of all Attributes assigned to the Components of an Assembly.
The size of the Assembly is limited to 1,000 Components, with no more than 100 Attributes assigned to each Component.
Note that an Assembly needs to be open when you launch this program.
Note that the largest assembly that I've tested this on was only 159 components. Also note that the program does not account for multiple occurrences of the same Component, listing them as if they were individual Components. This could be modified to only report duplicates once, but it would not be trivial.
As before, edit the file extension from .zipper to .zip before extracting the files.
Anyway, I hope this helps.
Have fun.
John R. Baker, P.E.
Cypress, CA
The Product 'Evangelist' or Unigraphics Gourou, with a lot of different UGS business card
Thanks a lot for your program
Is it possible to modify the Component_Attributes.grs to create in the same time the attribut file_spec for the complete part in assembly ?
Didier
As before, edit the file extension before attempting to extract the contents.
John R. Baker, P.E.
Cypress, CA
John R. Baker, P.E.
Cypress, CA
The new component_attributes programm report the file specification but doesn't create it !!
Didier
But that begs the question, if for example I have say 300 or 400 components, where is that you would like me to create this 'attribute' with the file spec for each Component, or are you only interested in the file spec for the Assembly file itself?
John R. Baker, P.E.
Cypress, CA
I am interested in the file spec for each component.
Didier
I ask this since so far the only file which I actually need set as the Work Part is the top-level assembly. If I'm going to write attributes to the individual component files, they will need to be set as the Work Part as I cycle the assembly, which I suspect will add considerable time the running of the program. And then there is the issue of what do we do with 'Read Only' parts? I suspect that the only way that I would be able to detect whether a part is 'Read Only' or not will be to actually attempt to save it and trap the error that will be generated when the save fails, but I may not be able to recognize this particular failure from any of the other possible failures which might occur. And in the case of family table parts, such as fasteners, they are BY DEFINITION permanently 'READ ONLY', and cannot be set as NOT 'Read Only' by the user, no matter what his/her level of system privileges might be.
John R. Baker, P.E.
Cypress, CA
