tension or compression in SW FEA results?
I am runnning a preliminary analysis on structural glass.  This is a preliminary study to define geometry.
Glass must only be in compression, never tension.
How do I tell whether the stress results that cosmos spits out are tensile or compression stress?
thanks!
RE: tension or compression in SW FEA results?
Von Mises stress is a positive scalar.  You need to use a different measure.  You will need to use principle strain.
