Looking for a threaded insert.
5/16-18" thread. .750 deep.
brass or steel.
looking for MS/NAS/MIL/AN. hopefully someone has insert p/n's memorized?
brass or steel.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Looking for a threaded insert.
Helical coil? Nahhhh maybe not... they typically come in 0.5XD multiples of the base diameter [1, 1.5, 2, 2.5, 3D]
Note: your depth suggests a solid-wall insert: light-weight [thin-wall], heavy-weight [thick wall], with coarse or fine outer threads???
Regards, Wil Taylor
close but is .3125-28UNJF
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Wes C.
solid-wall insert: heavy-weight [thick wall], with coarse inner threads, No outer threads (press-fit installation)
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
