Weibull B for Electrolytic Capacitor Failures
Can anyone suggest a suitable Weibull B parameter to use to model the wearout as a result of a single aging electrolytic capacitor in a consumer electronic product deployed in an indoor household environment.
Dave
RE: Weibull B for Electrolytic Capacitor Failures
If possible, try to locate actual test data from reliability tests to failure of similar components. If that is impossible, start with B = 1.5. In my work, betas in the range of 1.4 to 2 are common.
