BOM question
BOM question
BOM question
First off we use a excel based BOM.  It seems to work well for us so far.  As I do an assembly I pull in components basically willy nilly.  When I'm done I go back and rearrage components in the feature manager to group similar components together so when I create an order form like components are grouped.
My question is why doesn't my excell BOM follow how I have the components in my feature manager?  It does sort of but some components aren't in the order I put them.  I've looked briefly at SW BOM but due to lazyness I haven't dug to much into it.  Fot the most part the excel BOM works great it just doesn't follow the order I put things in.
Is that just how an excel BOM is going to work?  Is there an option I'm missing or a diff technique?
Grant
Applications Engineer
SW2008 X64 SP 3.1
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: BOM question
we're on SW 09 sp1.0
Grant
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: BOM question
This is probably of limited use, but I know in the SW BOM you can right-click the BOM and select 'follow assembly order'.  I don't know if the excel BOM has a similar function available.
RE: BOM question
That would help.  I will look into using a SW BOM.  One reason we like the excel BOM though is we have a formula to calculate weight from one of our BOM columns (its more or less to double check the mass props).  Can SW BOM do that also?
Grant
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
