Method for milling thread.
What method(operation type) is the best for milling thread (in one pass)?
Take a look at the picture in the attachment.
Method for milling thread.Method for milling thread.(OP)
Take a look at the picture in the attachment. Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Method for milling thread.
Do you need a machining answer or modelling?
What is the scale of the picture length and Outside Diameter are enough to describe it.
From a process point of view Lathe Thread Roller Thread grinder or even a milled 4th approach might be applicable. What is you're preference and why would you just thread cut it using lathe?
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
- NX6
- machining
- lenght 12mm diameter 4mm
- it's impossible to use lathe becase of material - Zirconium oxide It is very fragile before baking, so I use XZC mill and made profile with method "VARIABLE CONTOURE" with SURFACE AREA as drive options. The same method I tried to use for thread but with no result.
For these situations we drive the tool using a modeled helix curve. I'm not at work so I'll post a prt file on Monday.
Bill
Best Regards
Hudson
www.jamb.com.au
You may be able to us a thread milling operation. See the atteched part.
There is a thread mill operation as well as a fixed contour using a helix as the drive curve.
You did not say what the pitch of the thread is.
Thread milling is not your "standard" operation. It is actualy a UG Open routine and is quirkey. However it does work once you have all the parameters defined correctly. It uses the feature information from the Symbolic Thread feature.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
John posted the same type of examples I was going to post.
Bill
