Different Code
Different Code
A pressure Vessel (Bulk Storage Tank P=45 PSI)has been designed and fabricated as per ASME Sec VIII Div.1 but in name plate specified with different Code.
What is the best action to be taken for verification of design calculation?
RE: Different Code
You can use unknown variables, right? That would be your worst case scenario. If using unknown variables affects your operating conditions, then you could look into material sampling for stress values.
RE: Different Code
RE: Different Code
RE: Different Code
Attaching a picture or a pencil rubbing of the nameplate would help in shedding light to your mysterious vessel.
