oops - extruded cut when I meant extrude boss
I could delete the cut feature, and then just extrude the original sketch, but I made a few feature patterns that will disappear when deleting the cut.
Is there a way to "convert" an extrude cut to an extrude boss ?
thanks,
Dan T
thanks,
Dan T
RE: oops - extruded cut when I meant extrude boss
Dan
www.eltronresearch.com
Dan's Blog
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Dan
Dan's Blog
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I'm finding the negative dimension feature only seems to work in 2D sketches when the dimension is originally put in. I've yet to get one to work on an edit or in a 3D sketch. So far a pretty useless feature.
Joe Hasik, CSWP/SMTL
SW 09 x64, SP 1.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
