Tank drain flow rate and drain time calculations
I have a very simple problem, but I am trying to gain confidence in the calculations for drain down time and flow rate for a free-flow tank drain situation.
I have used free calculators at www.freecalc.com and www.e-funda.com, and I calculated the results by hand from my fluid mechanics notes. the hand calculation formula i used is
t = (area of tank)/([sqrt(2g)*area of pipe]*[integral_from h1_to_h2_of {h^-.5}])
simplified t = [A_t/(A_o*sqrt(2g))]*2*sqrt(h)
a 20000 gallon tank with 14 foot water height is draining out the bottom to a tank located just below it
I calculated for schedule 80 PVC pipe sizes 4, 6 and 8 inches.
I get drain down times of 2031, 902, and 510 seconds for average flow rates of 590, 1330 and 2350 gpm. That seems rather high to me, can anyone confirm I am even using the right formula / online calculators? this seems really simple but i just don't believe my answers...
RE: Tank drain flow rate and drain time calculations
2) Are you getting the same answers with the online calculators and your hand calcs?
3) Are they in the same ballpark?
4) Since you say your hand calcs are from your notes, did you check your textbook, to make sure you copied the formula correctly?
5) Since you give your times in seconds with a flow rate in minutes, did you do your conversions correctly?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
i did double check all my unit conversions (gallons to cubic feet, etc). yes the hand calculations
cvg - thanks for the photocopy, this does verify the formula I used. i see you are a civil engineer, do you have experience with industrial plumbing and flow rates? does around 600-2300 gpm sound accurate for a large tank free flowing through a 4-8 inch pipe with 14 feet of head?
There is that 'behaviour of falling(or Free-Falling)bodies'
under the effect of gravitational pull;sometimes,somewhat forgotten
but does impact vertical flows downwards much more noticeably
as may be felt/noticed on directionally upward vertical flow against the gravitational pull.
Best Regards
Qalander(Chem)
