Two speed reducer
Two speed reducer
Two speed reducer
Looking for a gearmotor that will automaticaly switch to slower speed to increase torque when higher torque is required.
Then return to higher speed when lower torque is required.
I assume that amp draw may trigger the speed switch. I have seen these used in applications, but I do not know the make of the drive package or whether it is the motor speed change or the reducer ratio change.
I am assuming it is a reducer ratio change to increase the torque at the slower speed.
Does anyone have any helpful information where I can get more details?
RE: Two speed reducer
Dealing with electronic packaging, this is really the wrong forum to field this question.  I suggest posting in the Mechanical Engineering and Other Topics forum.
Tunalover
How about a regular reducer with a 2 speed motor?
Russell Giuliano
I agree with the above. Don't complicate things if you don't have to.
peace
Fe
