FOUR WAY VALVE NON US MANUFACTURER
Dear all,
i am in the need and the urge to purchase a four way valve 10" 300# RF (it is for a bidirectional prover) but cannot find any non-US manufacturer or supplier. The valve indeed shall go to Syria and american company cannot export to that country.
Does someone know some manufacturers from other country than US?
Thank you for your time and attention.
Kindly,
francesco
Kindly,
francesco
RE: FOUR WAY VALVE NON US MANUFACTURER
2. I was, perhaps wrongly, of the opinion, that US could export 'non critical items' to Syria, althoug involving some paperwork?
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
let me thank you for your help. In this case, the bidirectional prover unfortunately requires the use of a 4-way valve to quickly revert the flow in the proving circuit.
thanks and regards,
francesco
Multiport sleeved plug valves large size available from
www.fluorosealvalves.com (Canada)
www.3zvalve.com (Korea)
The Nps-10 plug valve will require a gear actuator or very large power actautor. It might be slow to operate.
