Maximum Nickel content in H13 steels
what is the maximum content of nickel in the H13 steels ?
All the CODES AISI, German, french and others don't say any thing about the nickel on the H13 steel.
Thanks in advance
RE: Maximum Nickel content in H13 steels
Normally when  Ni is not a direct alloying element,the maxium permissible limits is 0.5%.
 H13,grade steel does not have Ni as an alloying element it can be present as trace element only limited to 0.5% max.
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
ASTM A 681 Standard Specification for Tool Steels Alloy states:
nickel plus copper equal 0.75 % max
