FLUID COUPLING's
FLUID COUPLING's
FLUID COUPLING's
Normally the FLUID COUPLING's are fill with oil or other suited liquid.
But also there are ones filled with small solid particles , the same used to shoot penning.
It is used to link an AC asynchronous motor rated  440 Kw @ 740 rpm , to a hammer mill in a Cement plant
Do you know any about it , mainly what is the generic name of such device so I can do a search?
I can not find it.
Thanks.
RE: FLUID COUPLING's
Dry fluid centrifugal clutch.
I first encountered them on large mixing equipment where they allowed a heavily loaded rotating drum to start turning.
Griffy
Hi Griffengm.
Thanks for your answer.
Seem to be the same I have.
Do you remember the brand name?
I can not find it by searching at the web.
I found it .
