substracting multiple self-intersecting helix
Hi.
I have to model a pulley with variable pitch.
I have the shaft, and the helix body, with the variable pitch.
The first 4 turns of the helix the pitch smaller than the diameter of the 'spring', what causes multiple self-intersecting body.
I need to substract the helix from the shaft, but after the substraction, the model falls apart.
I tried to split the helix and substract its pieces, but then the same thing happens.
Is there a way to simplify the helix body?
Any help would be appreciated
kukelyk
RE: substracting multiple self-intersecting helix
kukelyk
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
My job is the green shaft.
http
kukelyk
"Thru face does not intersect path of the tool"
i see the interference between them, so i got confused..
kukelyk
Attached is a zip with jpegs of the model with the cylinder wall intact and without, plus the model file I used to get the result.
I don't how this helps (maybe it doesn't), but is this the failure you are seeing?
thanks for your pains
do you have any suggestion?
kukelyk
I tried the same thing all the way through with a law controlled sweep of a circular section finding the same problem as the helix, so I'll save you the bother on that account.
I hope you are in some small part better off for this solution.
Best Regards
Hudson
www.jamb.com.au
kukelyk
