Assembly to weldment
I have an assembly that I want to turn into a weldment! If I save it as a part I get surfaces and not individual parts that can be detailed seperately. The assembly is a carry over from a previous job and should have been a weldment to begin with, now I'm using it in another job as a sub-assembly and this causes problems with the parts list of the main assembly, "parts only" displays parts of the weldment and "top level only" shows sub-assemblies I've used for convenience in putting the whole assembly together. If I can change the assembly that should be a weldment into a weldment it then becomes just a part in the main assembly parts list, problem solved, otherwise it looks like having to re-model it (big job).
Anyone got any ideas please?
Peter C
SW2009 x64 SP2.0
Dell Precision M6300
Peter C
SW2009 x64 SP2.0
RE: Assembly to weldment
Exterior faces
Exterior components
All components
Peter C.
