Going threw the Tutor's
I'm doing the tutorials in the SW2009 I'm at the section where you import a autocad file and convert into 3D. I did everything it said but I cant delete any entities without deleting the whole drawing.. in autocad this was because it was a block and had to be exploded. is that along the same lines in SW.
"Delete all the sketch entities except the upper cross-section and the line beneath it, as shown. Be sure to delete the entities in the upper cross-section shown on the right"
this is the quote I'm getting but i cant just delete one entitie without deleting the whole drawing.
What am I doing wrong?
RE: Going threw the Tutor's
If not you have somehow closed the sketch. In this state, when a single element is selected, the whole sketch is affected.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
"Click View, Sketch Relations to clear the display of sketch relations icons in the graphics area."
what does this mean?
