continuous measurement of temperature of cast iron stream
is it possible to measure the temperature of continuous stream of cast iron from pressurized pouring furnace spout with a contact sensor ( B or N type ?? ). Non Contact is not an option because of its uncertainty in calibration and difficulties with slag etc.
If it is possible , using a contact sensor to measure the temperature of the stream continuously, does anyone know of any company specializing in this field??
Any help would be greatly appreciated.
It is a miracle that curiosity survives formal education.[Albert Einstein]
RE: continuous measurement of temperature of cast iron stream
What advantage do you get by continuously monitoring the stream. Instead measure the temperature before pouring and after completion of pouring. This will give you a fairly accurate idea of metal temperature.
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
Though, there are lot of companies which are selling the sensors (OMEGA to start with and a lot other)
A great respect for you experience arunmrao !
