Effect on Pressure
Effect on Pressure
I was wondering if anyone could help? In a closed pressure vessel, heating up a solution will obviously increase the pressure.
If the volume of solution is increased (the headspace reduced) prior to heating, and the same solution heated to the same temperature, will the pressure differ?
Thank you
Thank you
RE: Effect on Pressure
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
Good luck,
Latexman
