markets for positive displacement pump
With few crazy guys we are preparing the program for tests and certifications for a totally different positive displacement pump (unbelievable, but true).
Industrial trials in truly harsh environment (large volume batch synthesis) have revealed quite a few interesting qualities. For example the reduction in energy consumption was really significant. In addition, the pump has been able to fill itself from evacuated vessels. Small hard impurities seem to present no big problems. We also solved the problems related to frequent pressure/vacuum switches.
Currently we are having argument inside the team: which market might have the highest need in different pumping opportunities. We evidently do not have cash to pass all tests and certifications for all potential applications.
We feel ourselves quite confident about claiming low energy. However, we are limited with the capacity - up to 60 m3/h and pressure of up to 8 bar.
Any ideas about targeting the attention?
RE: markets for positive displacement pump
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
The presented efficiency is conservative.
Will Your new configured pump rotate from back pressure of the fluid originally being pumped?
Just asking if the device can be used as a hydraulic motor.
At 74th year working on IR-One2 PhD from UHK - - -
