convert pdf to dwg
convert pdf to dwg
"Judge (Mechanical) 22 Sep 06 22:23
I have alot of old 2D drawings on paper, which I am in the process of scanning & saving as pdf files. Is there any way to convert these scanned pdfs to dwg format? I have tried AutoDWG but it only works for original pdf files not scanned pdfs. Any suggestions would be much appreciated.
Thank you"
This is a question of eng-tips,but this thread has been Closed.
http://www
RE: convert pdf to dwg
you can try the new release of the stand alone version of AutoDWG. It is now support raster to vector conversion including converting scanned PDF to editable vector DWG.
http://www.autodwg.com/pdf-to-dwg-converter/
Good luck!
