SAE Grade 8 Bolting in low temperature service
I have 4000 bronze bodied three piece ball valves with Grade 8 bolting. The manufacturer has rated the valves to -20 F service conditions.
I am using the valves at 1/3rd the rated valve pressure and want to know how I can justify a lower working temperature based on the lower working pressure I am using the valves in.
I do not want to change out all 4000 valves with SS bolting if I can help it.
Can someone show me a method to rate Grade 8 bolts to temperatures of -30 F. The bolt sizes wre 5/16" to 1/2"
RE: SAE Grade 8 Bolting in low temperature service
Just because your pressure is lower doesn't mean you can lower the temperature that the valves can take.
Also, you can't just replace the bolting; you also need to verify that the valve themselves will withstand the lower temperature.
I suggest contacting the manufacturer and asking about the servicibility of the valves at the temperatures you need.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
