Trying to learn Nikasil or Electroplating for cylinder bores
We have a part here that is an automotive type bore that requires a nickel silicon carbide coating on the inside of the bore. This is typically done by electroplating I believe. We would like to look into doing this in house because the prices for this service are ridiculously high.
Could anyone either recommend a reasonable plating company for larger quantities or recommend resources to learn the process and find equipment to do it in house?
RE: Trying to learn Nikasil or Electroplating for cylinder bores
http://www.uschrome.com/nicom_ds.html
I'm not sure what to recommend for references. Most of this is proprietary technology, and doesn't seem to be included in most technical books. Maybe start with a Google Patent search:
ht
If you have unlimited time and money then go ahead. They are fascinating technologies.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
