SAE Gr 8 bolting in Low Temperatures
I have 4000 bronze bodied three piece ball valves with Grade 8 bolting. The manufacturer has rated the valves to -20 F service conditions.
I am using the valves at 1/3rd the rated valve pressure and want to know how I can justify a lower working temperature based on the lower working pressure I am using the valves in.
I do not want to change out all 4000 valves with SS bolting if I can help it.
Can someone show me a method to rate Grade 8 bolts to temperatures of -30 F. The bolt sizes wre 5/16" to 1/2"
RE: SAE Gr 8 bolting in Low Temperatures
http://www.eng-tips.com/threadminder.cfm?pid=408
