Dia. Dimensio on Drawing
I'm putting in a diameter dimension on a detailed drawing sectional view. I want to be able to put in the dia. symbol automatically when I put in a dimension. Is there any way to do this besides doing it manually?
RE: Dia. Dimensio on Drawing
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Mechanical Designer
Chris
ctopher's blog
SolidWorks Legion
Mechanical Designer
Anyway...
How are you dimensioning the part? If you dimension to a circle, it should add the dia symbol.
Chris
ctopher's blog
SolidWorks Legion
