Efficiency gain DC to AC motor?
I have 6 DC direct drive motors on a production line that are aging and will be replaced with AC motors. Are there any rules of thumb I can use to determine efficiency gain? The existing DC motors are between 1.5 to 5 HP, and are using 240V single phase, amps measured on the AC side are 2A to 11.5A depending on HP.
I don't have the specs for the new motors, but they should be AC and probably the same HP rating. Any help would be appreciated, thanks.
RE: Efficiency gain DC to AC motor?
Since the AC drive is double conversion and a DC drive is single conversion, I would estimate the difference in losses to be around 1% with the DC being better than the AC.
Maybe someone else on here has some reference material. If so, please volunteer.
