Automate NX5 plotting
Hi all, my company uses NX5 and I have been asked if I can help get an electronic copy of our drawings (currently we only have hard-copy drawings) our options are:
1) scan all the drawings - a huge job!
2) manually open and print the drawings (to pdf) - another huge job!
3) automate the opening, printing and closing of each assembly - sounds simple when written like this...
I read a few bits on this site about Macros and NX and also the API but can anyone give me a pointer as to the best way? Has anyone already done this? (I don't want to reinvent the wheel...)
Any advice / guidance would be appreciated.
RE: Automate NX5 plotting
If there is a really good way to do what you are doing I would love to hear about it.
Might I suggest that unless the numbers of drawings run to say more than a thousand that you'd probably be able to set up some macros and sit a work experience kid in front of a tube more cheaply than the time it might take to automate such a process.
On the other hand if you or any other person does or has developed a program by way of automation that will do this EVERYONE who uses NX wants a copy! I'm sure that after the number of times it has come up here that we'd be extremely annoyed if you didn't share something like that with us.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
There should be a cgm file imbedded in your NX5 files. There may be a way to access that and create a pdf from it.
If you get stuck, record a journal and see what the code looks like. Once you are happy you can compile the journal into a executable program if you have the author license.
Suresh
Any time you can get it to batch process a bunch of files then you'll have jumped that hurdle that we're all struggling with.
Best Regards
Hudson
www.jamb.com.au
