NX6 tracking bar
NX6 tracking bar
My coworker lost his tracking bar (it shows up in edit curve parameters and basic curves among others). The NX2 era tricks for getting it back don't seem to be working.
Any suggestions?
NX6.0.0.24
Any suggestions?
NX6.0.0.24
RE: NX6 tracking bar
Best regards
Simon (NX4.0.4.2 MP9 - TCEng 9.1.3.6.c)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Any other tricks?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
If someone else opens the file they have the tracking bar; if he opens a different file he has the tracking bar back. If he then opens the file in question - no tracking bar.
So technically it is not part specific, though it is unexpected behavior.
It's fine on the 1600 X 1200. Nothing outside the bounds.
Right click on desktop taskbar->Properties->and select "Auto-hide taskbar"
click OK
Goto line command (in "basic curves" dialog)
You can find the "Tracking bar" behind the "Desktop Taskbar"!!!
The 'reset window position' option worked, but only when a command that uses the tracking bar is running. So while the basic curves dialog is open, navigate to Preferences -> User interface... {layout tab} and press the 'reset window position' button.
