InRoads compatibility with AutoCad
My company like many others is making the switch to InRoads. We our curently using AutoCad. What are the issues with data transfer between the programs? Is file conversion neccesary?
RE: InRoads compatibility with AutoCad
I am not familiar with LDD if that is what you are using for AutoCad as a Highway Design package. InRoads is a add-on to Microstation. They work in conjunction with each other. All Autocad files will have to be translated to Microstation. I think what you are up against the most is the translating between Autocad and Mircostation. After that, InRoads can be used to develop DTM's and linework.
Good Luck, I would suggest a class by Bentley to introduce you to InRoads. But first, you will need to know Microstation.
