3D Thrust Block
3D Thrust Block
3D Thrust Block
Good day,
Does anyone know where i can find information on how to design a 3D thrust-block. The pipeline that we are designing have composite vertical and horizontal bends.
Thank you.
RE: 3D Thrust Block
Retaining wall design active and passive pressure method is applicable, if you're talking about a buried anchor.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
RE: 3D Thrust Block
The pipeline is above-ground. I need to calculate the thrust at pipe angles that bend in the x-y-z directions.
RE: 3D Thrust Block
What do you know about pipe stress analysis?
