Voltage Drop from Meter
What is considered the average or normal voltage drop from my meter to my breaker panel? I understand the ANSI standard range for service voltage at meter is 114-126V and 110V minimum at the receptacles, but what is % voltage drop should one expect at the main breaker panel? thanks!
RE: Voltage Drop from Meter
You can compute -- look up AC resistance for the size wire in your feeder, and do the V = I * R thing.
Good on ya,
Goober Dave
