USING 3D FUNCTIONAL TOLLRENCING & ANOTATION
Dear All,
is it possible to make a 3d anotation modell in assembly mode. The problem which i am facing is that, while i am opening an part model(e.g for *.CATPart) and try to make a anoted model it works well, but wen i am attempting the same for the asembly model (e.g for *.CATProduct, Specificly while changing product to 3d tollrencing and anotation) a create new dilogue box opens.
please any body tell me the procedure how can i make it possible for a assembly model.
Rregars
Sanket
RE: USING 3D FUNCTIONAL TOLLRENCING & ANOTATION
There is a dedicated module for FT&A for products and I think it even is called "Product FT&A"
AZREL THANKS FOR YOUR REPLY . BUT I DID NOT FOUND THAT WORK BENCH.. EVEN YOU TRY TO FOUND IN www.kxcad.net  ....
Open an assembly file first, and then start the Product FT&A workbench.
I think that on the documentation both modules are covered under FT&A, same functions..
thanks arjel & jakk i had found that one..... thanks a lot,,
