Data in a table
Data in a table
Data in a table
I need a visual basic code to pick up the data in a table. Please help!
RE: Data in a table
Does it have to be VBA?  Using the ranges in your sample file the formula below will give what I think you want:
=INDEX($C$17:$Q$24,MATCH(H9,$B$17:$B$24,0),MATCH($B$9,$C$16:$Q$16))
If you do want to get the table data into a VBA array then give the table range a range name (say pipe_data) and create a VBA variable of variant type (that could be pipe_data as well) then:
Dim Pipe_Data as variant
Pipe_Data = range("pipe_data").value2
Will get all the data from your table into the VBA array.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
RE: Data in a table
Thanks Guys!
