Class I Standpipes on Roof
I have a fire inspector requesting that Class I Standpipe outlets be placed on the roof a structure such that all points of the structure are within 150 ft. of a connection. It has always been my understanding that NFPA 14 requires standpipes within 150' of every floor level for non-sprinkler buildings, and 200' of sprinklered buildings, but roofs do not need to meet these requirements because they are not occupied space. If it were a simple matter of taking each of my existing standpipes to the roof, it would not be much of a problem (especially since most of them are already there). However, the roof of this structure is cut up into various areas of flat roof and pitched roofs. There are several flat areas that are quite a distance from the nearest stanpipe, and are completely surrounded by pitched roof. Has anyone encountered an official requiring anything like this? Can someone provide some insight into the NFPA 14 requirement, or give me a logical argument that may help explain the intent of the code for this situation?
RE: Class I Standpipes on Roof
http
While the revision to Section 7.3.2 isn't official I've always had pretty good success in using proposed changes to bolster my position when the change is proposed by a committee member, the vote by the committee is unanimous in the affirmative and language includes "verify" or "intent".
than if it is produced you can read an dipute if needed.
maybe local admendment??
