Open query using parameters in MS Access
Hi all,
I'm a Control Systems Engineer with not much experience in database programming, but I am trying to create an application using MS Access. I realize I may make a fool of myself asking this question, but I'll just have to risk it.
My database has several tables. The first table contains the panel numbers:
ID | Panel number | Description
1 | P-001 | Control panel
2 | P-002 | Network panel
3 | P-003 | Remote I/O panel
The second table contains an overview of materials:
ID | Description
1 | Enclosure
2 | Terminals block
3 | Cable gland
In a third table I keep track of the amount of materials per panel:
ID | Panel ID | Material ID | Qty
1 | 1 | 1 | 1
2 | 1 | 2 | 40
3 | 1 | 3 | 6
4 | 2 | 1 | 1
5 | 2 | 3 | 7
6 | 3 | 1 | 1
7 | 3 | 2 | 25
I have created a form to show the panel list (i.e. the first table), and want to add a button to this form that will show the materials in the selected panel.
I have already created a query that shows the panel name, material description and quantity for all panels, but I want the query to only show the data of the currently selected table. I know I can open the query with a parameter, but would like to know how I can automatically use the "panel ID" as the parameter?
Thanks for your help.
Caspar
ID | Description
1 | Enclosure
2 | Terminals block
3 | Cable gland
1 | 1 | 1 | 1
2 | 1 | 2 | 40
3 | 1 | 3 | 6
4 | 2 | 1 | 1
5 | 2 | 3 | 7
6 | 3 | 1 | 1
7 | 3 | 2 | 25
Caspar
RE: Open query using parameters in MS Access
TTFN
