Generator start wiring
In the standby system with multiple ATS's shall the generator start wiring from each ATS run directly to generator as homeruns or I can connect several ATS's wiring and run it just as single homerun?
Is it a Code issue or just good practice?
Thanks in advance.
Thanks in advance.
RE: Generator start wiring
So the real question is do you want to be a good engineer or a bad one? Can you (or not) understand the pros and cons of the two approaches? Do you really want one broken wire take down entire facility?
Make your own decision.
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". – Nikola Tesla
But there are always exceptions.
Bill
"Why not the best?"
Jimmy Carter
