Feature Parameters
Feature Parameters
When I insert the Feature Parameters for a threaded hole feature, i could not get the dual dimensions. Currently my setting in dual dimensioning & when i do the other dimensions its perfect, but when i call out the feature parameter dimensioning its doesn't follow the parameter set in dimensioning. Even the arrows not filled & only i am getting the english dimensions .My secondary dimension unit in metric. Is there any way to solve this.
Thanks for your favourable replies & for your Favourable times.
G.Vijay
G.Vijay
RE: Feature Parameters
Vijay
G.Vijay
