External threading URGENT
I have been given some drawnings to model and assemble.
How do i make an external threading with a size of M6*1.
The part will fit into a hole.
RE: External threading URGENT
Search "threads" in the Help files.  You probably don't need to model the true helical threads, right--since the M6 callout would then be redundant.  If you really need the helical stuff, search for "sweep" and "helix" in Help.
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
McMaster-Carr has great examples, you may even be able to use a screw right off their website.
-Brian
NUFCshearer,
   How good do these threads have to be?  Are you preparing a drawing with threading instructions, or is your solid model going to be used for manufacturing tooling?
               JHG
If you really don't need the threads, don't model them. It takes up a whole lotta space.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
(I guess it wasn't that urgent after all.)
Jeff Mowry
LMAO! That's funny Jeff!
}:O)
Mechanical Designer
