Openings that are not round or elliptical
Gents,
I'm a relatively inexperienced Compress user.  I have a vertical vessel that has a tapered transition bottom 'head', and a shallow tapered transition top 'head'.  The bottom transition terminates in a concentric nozzle...easy enough by making the nozzle neck a 'cylinder'.  The problem is that the top needs one square and one rectangular connection.
Can this be done in Compress?
Fitter, happier, more productive
RE: Openings that are not round or elliptical
Hello BigTank,
You are correct that the circular nozzle at the small end of the transition is a cylinder. It may function for the process as a nozzle but structurally-speaking, per ASME Code, it is a cylindrical shell section.
COMPRESS does not provide for analysis of square or rectangular sections. Sorry.
   "Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
  www.codeware.com
options to model these odd openings...
who would approximate the opening area using a round opening?  wouldn't the corners of the actual real-life square or rectangular openings cause stress concentrations that would render the approximations invalid?
Depends on the corners and depends on the rectangle. For a square opening, or rectangle with a relatively low L to W ratio (2:1 or less), if you have generous corner radii to reduce stress and calculate a circle with a diameter equal to the diagonal distance corner to corner, your AI may go along with it. Since there are no Code rules, you are in U-1(g) and must justify "safe as Code" by whatever means you feel is valid. Of course with rectangular openings if the long dimension is in line with the longitudinal axis and is more than 3 or so times the width, you may have a hard sell without FEA or some serious stress intensifier factors.
