PPlication of Aluminum Brass B148-955 in sour water service
Does anyone have experience in the application of Aluminum Brass alloy B148-955 in centrifugal pumps for refinery sour water service. Severe housing and impeller   corrosion has been experienced. Would like to know what material will be best for this service.
RE: PPlication of Aluminum Brass B148-955 in sour water service
316/316L will be a starting option in alkaline sour water.  If the water is acidic with chlorides (probably not otherwise you would not have lost the  nickel aluminium BRONZE), ISO 13709, Material Class D-1, duplex stainless steel should do.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
