Crack in NDE Bearing greasecap
Hi forum experts,
We recently did the first overhaul of our 6,0 MW 11 k V wound induction motor. This is a quite new motor, three years of service.Attached is a picture of the NDE bearing greasecap. You will notice traces of cracks close to the grease line and grease exit.Also visible are traces of uncleaned paint in the cavity of the grease exit.We believe this dated back to factory.
We did not notice any abnormal vibration during the operation of the motor. It has been running trouble free since installation. We overhauled the motor because we were pushed to do so by the insurance company.
I would like to have the views of the forum on the possible cause of these cracks.
Guardiano
Guardiano
RE: Crack in NDE Bearing greasecap
6 MW machine on anti-friction bearings ? What is the speed and what are the bearings ?
Thanks for your reply. It`s a 8 pole motor and there are one roller and one ball bearings on the NDE. I tend to agree with you about the poor design.
Guardiano
Only a ball bearing + a roller bearing ? Hmmm. I would have expected at least (a roller + a ball bearing + a roller bearing) or (a spherical roller + a roller bearing) combo.
What are the rotor weight, rotor speed and the bearing nos. ?
Keith Cress
Is there in fact some kind of very deeply worn groove in that bore, for instance most visible just below the left crack?
If so I'm thinking improper housing diameter allowed bearing to spin which wore a groove which weakened the housing.
Both vibration and temperature monitorings are done on this motor and nothing suspect were seen.Electricpete,we have not yet verified the bearing housing but the tolerance of the roller bearing is ok. Basically, there is no axial load on the greasecap because the latter acts merely as a shield.
Guardiano
grease discharge retangular slot. Cavitity is bad casting that made it through QC. Looks like a TECO bearing cap as they use that blue paint on machined surfaces. I can see the grease discharge tube below the cap that connected to the grease cleaning tube. The cracks I have seen before, when brg cap is assembled a bit off center onto motor end bracket using a air impact gun to tighten the brg cap bolts.
Guardiano
I think you can operate the motor without any problems.
Does the NDE bearing have a snap ring on the shaft that acts as backstop to the bearing? If so, then the bearing cap is just keeping the grease in place and dust etc out.
Mac
