Guide line for ball diameter selection in BALL VALVE
Hello
I am designing  Fire shutoff valve(Ball valve)
Is there any guidelines available for selection of ball diameter in ball valve
And is there any relation available for orifice diameter to ball diameter.
John
RE: Guide line for ball diameter selection in BALL VALVE
You should be able to provide a bore hole diameter equal to pipe ID.
Draw a cube around the pipe and make the surface of the ball intersect the corners of the cube.  That's the minimum sphere diameter.
There wouldn't be much use for a larger ball than that.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
For rule of thumb, the bore diameter is 60% of the sphere diameter.  That tends to be a minimum.  But you need to check the contact area with the seat.  The above ratio may not ensure full contact area all around the seat when the valve is shut.
bcd
Not bad.  The circumscribed cube method gives a full pipe diameter bore equal to 57.7% of sphere diameter.  We could call it 60%.
