Maximum Amperes (AF/AT)
Dear All,
is there anyone knows, that in this attached catalog,
The "maximum amperes" refer to Frame rating or Trip rating?
Thank you very much
RE: Maximum Amperes (AF/AT)
Looks like frame rating to me.
It's  both. However the frame size (physical dimensions, AIC rating etc) is fixed for a given model/frame type. You can get the rating plugs or adjustable trip units equal or below the maximum ampere rating.
So you can get maximum of 250AF/250AT in a KH model, or you can also get a 250AF/150AT. Both units will physically be the same, except for the trip rating.
A side note: Usually the lowest trip rating you can get is 0.5X the frame rating. There are some expceptions.
