Drawing View Properties
Previous to SW 2009 I was able to go into the Drawing View Properties and select a different configuration of the assembly and select the check box "Link balloon text to specified Bom" then hit the click down and select the Bill of Materials. I'm not sure what changed but I can now see it but it's grayed out. This allowed for using different configs and keeping one quantity column with the correct quantity. Any help to set me straight would be appreciated. Thanks in advance.
RE: Drawing View Properties
I did a test on my test workstation SW2009 SP2.0 and seemed to work just fine.
Best,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
I'll test again on my end.
Also, what Service Pack are you on? That makes a difference.
I'm test SW2009 SP2.1
Mechanical Designer
you can do 2 of the workarounds:(that not always worked in SP1 and SP2 my machine is SW2009 SP2.1), such as:
Workaround 1 (changing the Windows folder theme) 1. Minimize SW window 2. RMB on the Desktop > Properties > Themes, choose "Windows Classic" or Windows xp (also without closing SW), the option is not greyed out (in my machine)
Workaround 2 (switching off and on all the Add-Ins) 1. Switching all the Add-Ins on, one by one (keeping all the other off), 2. And seeing, for every step, if the option is 'usable'? (f.i. the Add-Ins that makes the difference in my pc is Solidworks Simulation, if I switch it on, all the others off, the option is usable). As you reported, turning on 2d Emulator Add-In, the problem disappeared.
The problem should be solve in SW2009 SP3,
thats according to SW.
hope that it will help you.
Same problem. I have config A on sheet 1, and both config A and B on sheet 2. I made Excel BOMs for each config on sheet 2 and hid them, but the check box to select the BOM for the balloons is greyed out.
I tried both workarounds, no luck. I have SW2009, SP3.
Steve
