Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you for the best reply I've ever had to a forum question - it's extremely comprehensive and legible and answers my query thoroughly..."
Geography
vscid (Nuclear)
6 Feb 09 15:04
Where can I find metric socket wrench clearances ? I looked in the machinery handbook, but in vain.
thanks!
CoryPad (Materials)
6 Feb 09 15:54
Clearance between what two objects?
Eltron (Mechanical)
6 Feb 09 15:57
Why not just measure one?
Dan
www.eltronresearch.com
Dan's Blog
Timelord (Mechanical)
6 Feb 09 16:12
Depends on the wrench.  I have some Craftsman sockets that have almost double the wall thickness of the same size Snap-On socket.
Timelord
btrueblood (Mechanical)
6 Feb 09 16:13
Socket diameters can vary, by quite a lot, for both metric and imperial tools.  Depends on the manufacturer, type of steel and expected use of the socket.  Oh, and cost.
ctopher (Mechanical)
6 Feb 09 16:56
Does this help?
http://icrank.com/cgi-bin/pageman/pageout.cgi?path=/data/wrench/wrench.html&t=2
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
rmw (Mechanical)
6 Feb 09 22:28
I remember seeing the dimensions in tool catalogs for tool product names like Proto that you can get from auto and truck parts houses.
Try this for a start; http://www.stanleyproto.com/xhtml/LITERATURE/PROTOCATALOG_P20800_IMPACTSOCKETS.PDF
rmw
6 Feb 09 22:44
There is a MS standard, I can't find it right now.
Chris
ctopher's blog
SolidWorks Legion
juergenwt (Mechanical)
7 Feb 09 2:43
vscid - Tolerances for metric wrenches are listed under DIN 475-2 or ISO 691.
If you need just a few - post what size and I will get it for you. If you need many sizes - google and you may have to buy a book. Best source - "Beuth" ask for their English version of DIN 475-2 or ISO 691.
TedMac (Mechanical)
19 Mar 09 8:15
Just going to throw this out there, but any chance you would be able to let me know what the tolerance is for a 7mm wrench?
It would be greatly appreciated.
racookpe1978 (Nuclear)
19 Mar 09 10:48
Tolerances for a socket wrench?
Realistically, can you really expect your "average" mechanic or millwright to have a socket in his toolbag that is so close to "not fitting" - given the above where socket walls between manufactorers and suppliers so differs greatly! - that you (as an original designer) needs to consider fabrication tolerances in order that HIS socket will fit between YOUR nuts?
I think you need more space.  Or a specific, designated socket wrench YOU will supply WITH the machined flange YOU are selling that will permanently stay with that flange for as long as the flange will need maintenance...
TedMac (Mechanical)
19 Mar 09 11:50
I found my answer in another thread.  Thanks.
Looking back I guess my question was not clear.  I was looking for the standard clearance range between the flats of a open faced wrench and a nut/bolt head (DIN 475-2).  I would like to use a hex head bolt in a non traditional way and want to insure that there is never an interference, so I figure the easiest thing to do is mimic the clearances on a wrench since there is never an instance were a wrench does not fit a nut/bolt.
So again sorry for not being more clear, and making you waste your time with an answer that is not applicable.  Good day
MotorVib (Mechanical)
19 Mar 09 11:58
As a quick check on project I have just used a standerd flat washer.  If a standerd flat wash will fit then there should be room for the socket wrench.
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
dinjin (Mechanical)
19 Mar 09 15:39
You might want to check our Maryland Metric.
They have a lot of tech info on their site.
http://mdmetric.com/fastindx/inxtst.htm
TedMac (Mechanical)
20 Mar 09 6:25
dinjin,
PERFECT, that is an Awesome resource, thanks for posting!
Close Box
Join Eng-Tips® Today!
Join Us             Close
