Default settings in hole wizard
Is it possible to change the default settings in the hole wizard (Part modeling)
Please see the attached image, need to change the neck chamfer angle of the Counter bore hole from 0 to 90.
RE: Default settings in hole wizard
Can't you save it as a favorite?
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Just type in the required angle. The HW will remember the setting.
cheers
Thanks CorBlimeyLimey,
I am just beginner to SW and trying to learn.
This was part of my learning.
Thank you once again..
