Problems with Appearance in Assy
Hello, I am working on an assy and somehow the appearances changed. I have attached the assy as well as just the part. I would like the assy to return to the standard view. I would like to view the assy the same as the part with default settings.
Thank you for your assistance.
RE: Problems with Appearance in Assy
You can change the appearances in the tree.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
In your assembly browser, right click, expand the menu, and look for "Change Transparency". That might be your problem.
