Blower Differential Pressure
I am new to blowers and need a little help.  If I have a inlet pressure of 12 psia on the inlet side of the blower and a differential pressure of 6 psi what does that tell me?  I expect it means the outlet pressure is 6 psi and 6 psi is lost to the equipment?  If I was using this blower for aeration would the available psi for a diffuser be the 6 psi minus the friction losses?  Thanks for the help
RE: Blower Differential Pressure
How can you have a positive pressure on the inlet side?
Outlet pressure minus friction losses is correct for diffusers.(Then consider depth of water)
Thanks for the reply.  Some information I looked at said the inlet pressure was 12 psia, which I take as 12 lb/in^2 atmospheric for the elevation of the blower.  Can you explain why the pressure should be negative on the inlet side then.  Thanks again.
The notation psia means "atmospheric" pressure. Atmospheric pressure at sea level is 14.7 psia = 0 psig. "g" stands for gauge pressure.
psig is pressure relative to a reference point, typically ambient pressure (usually safe to assume 14.7 psia, unless your calculation is for a pressure relative to that in a liquid column, e.g. at seabed conditions).
12 psia would equal -2.7 psig.
Ask your supplier what the blower discharge pressure is.
Pressure measurement is a reference to nominal sea level atmospheric pressure of 14.7 PSIA. For example, a blower producing an outlet pressure of 17.7 PSIA at sea level is creating a differential of 3 PSI.
A differential pressure of 6 psi across the blower should be a discharge pressure gauge reading of 6 psig.
Thanks for all your answers
